Low Budget Projector?
QuitePurple
78
I have $70 to spend. I've been seeing projectors for that price on amazon quite a bit. I just don't know if they're any good.
Yeah, I know that to get a great projector I'd need more money. I just want to know if anyone has a good, cheap projector they'd recommend.
I'm planning on projecting onto a wall, not a screen. I'll probably make a screen sometime in the next month or two.
Any help is appreciated!
P.S. I was looking at this, but I don't know anything about the brand, or the projector itself. http://www.amazon.com/Beyondtek-Multimedia-Resolution-Presentations-Projection/dp/B00PV9GO8M/ref=sr_1_13?s=pc&ie=UTF8&qid=1422129228&sr=1-13&keywords=1080p+projector#customerReviews
Might as well get the one I suggested since it's free shipping. If your hell bent on getting something under 100 then you got this...
Sorry for the long response time. That projector looks good, but the shipping is $45 from china... XD
Might as well get the one I suggested since it's free shipping. If your hell bent on getting something under 100 then you got this; http://www.amazon.com/dp/B00S0FX2W0?psc=1
It's 65% off, so it'll be in the price range. Can't do much better then that.
