low budget system
gramzon
41
Can someone help me create a low budget gaming system that will be used to play MMORPG's mainly like WoW and Warhammer.
The price should be around 500$ without the monitor.
vegettonox
617
45
Finally a challenge.
since you stated without the monitor im going to assume you may have a system lying around that you can get a keyboard and mouse from.
if not just pick up a **** combo setup from wally world or your local comp store.
DVDRW
LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM
Item #: N82E16827106228 $23.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106228
CASE+PSU
hec 6C28BBX585 Black Steel ATX Mid Tower Computer Case 585W Power Supply - Retail $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121002
HARD DRIVE
Seagate Barracuda 7200.10 ST3160815AS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148230
MOTHERBOARD
MSI K9A2GM-F V3 AM2 AMD 740G Micro ATX AMD Motherboard - Retail $52.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130188
MEMORY
mushkin 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model 991527 - Retail X2 $47.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146117
PROCESSOR
AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000CZBOX - Retail 112.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103773
VIDEO CARD
ASUS EAH3870/G/HTDI/512M Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
$104.99 - Comes with Alone in the dark for the pc.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121217
Comes to a total of $464.09 with shipping. this will effectively rip through whatever you want to play.
If you want to push the price to the limit.
bump the hard drive up
SAMSUNG HD642JJ 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - Retail 84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152134
pushes the total with an estimated shipping to $501.28
(there is some room for adjustment you could obviously skimp on the hard drive and add a second cd burner or add a floppy drive or get your keyboard and mouse if you dont have them.
I highly recommend this will perform very well for you.
Wanker79
223
I don't know anything about the PSU that comes with that case, but I'd be very hesitant to trust it (especially since it's so cheap). There's no reason to buy IDE when SATA is basically the same price with much better air flow. And I'd only recommend matched pairs of RAM so that there isn't any issue with running in dual channel. You could just adjust vegettonox's build to include those suggestions, but here's an intel build to give you some options:
Case: Rosewill ATX Mid Tower with dual 120mm fans = $54
CPU: Pentium E7200 Wolfdale = $120
MoBo: BioStar TForce TP43D2A7 = $80 (after MIR)
GPU: ASUS HD3870 512MB 256-bit GDDR4 = $85 (after MIR)
RAM: OCZ 2x2GB DDR2 = $54 (after MIR)
HDD: WD Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s = $44
PSU: OCZ StealthXStream OCZ600SXS 600W = $50 (after MIR)
Burner: Asus 20x DVD +/-R SATA DVD Burner w/ Lightscribe = $37
The E7200 and TForce TP43D2A7 are a combo deal right now and the case and burner are also a combo for a combined savings of $35. So that's $489 after MIRs and before shipping/tax.
Wanker79
223
If you don't have any interest in OCing, vegettonox's AMD build is probably better (although all the caveats I mentioned still apply). If you want to OC, then the Intel build I put up is probably better.
aevm
Illustrious
That E7200 build is better than the AMD build, with three conditions:
1. you must add about $40 for a good aftermarket cooler (e.g. Xigmatek HDT-S1283 + retention bracket, or Sunbeam Core Contact, etc.)
2. you must have the time and skill to overclock
3. you must still be able to get a good video card
That is, overclocked E7200+HD 3870 will suck compared to stock X2 6000 + HD 4850. If you can't afford both the cooler and the video card upgrade, get the video card upgrade and the X2 6000. It will pay off in most games because the GPU matters more.
ohiou_grad_06
3,420
55
For low budget build that PSU might work. It's rated as 20 amps on one rail and 19 on the other if I'm not mistaken. If I HAD to pick a low budget PSU around 30 bucks, that's probably what I'd buy. Though I've never owned one, it looks good on paper and gets good newegg reviews. Look at PSU's, and then at a brand called compucase. If that's the same psu as the 585 watt ones there, it may do ok. Though it also might be better to spend more and get a more quality unit.
effel
248
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=9002566
http://www.buy.com/prod/antec-three-hundred-atx-computer-case/q/loc/101/207906549.html
I took some hints here and there, and this is what I came up with. It's honestly closer to $560, but I feel the extra you pay is pretty justified. Getting the 6000X2 doesn't seem worth it, because of the TDP vs. the 5400. 65w 2.8ghz vs 125w 3.0ghz that's also $30 less. I know you can cut a few corners on the build I put together, but it does it need it?
Wanker79
223
Yeah, I did forget to add a cooler. And the more I look at it, the more I agree that the X2 6000+/HD4850 is the way to go. And if you really want to save some more you could probably substitute a 2.9GHz 5600+ ($103) or even a 2.8GHz 5400+ Black Edition ($90 but you'd need an aftermarket cooler) for the 3.0GHz 6000+. You'd be losing L2 Cache, but you'd be getting newer 65nm tech and dropping from 125W to 65W.
genored
83
Get a sonata III (has 500w antech earth watt) 100$
2x1gb 800mhz cl5 47.5$
amd 4850e 2.5ghz 77$
Ati 4850 512mb 199$
thats about 423$ and 77$ left for a motherboard
aevm
Illustrious
genored
83
hehe sorry i'm swedish i dont really know how newegg works. Its more picking the right components. If you want to wait a short time amd will release a motherboard that will be cheaper then the 790GX with SB750
vegettonox
617
45
Alone in the dark starts off slow for the first "level" after that the game gets more and more entertaining as it goes on. i definitly enjoyed playing it and couldnt pull myself away till i beat it. usually a sign of a good game. well put together awesome levels and music is awesome as well.
Similar threads
