Case = CM Storm Trooper Full ATX (2 fans on front pulling, 1 fan in rear pushing, 2 on top for radiator pushing through the rad out the top of the case)
MB = Asus M5A99FX Pro 2.0
CPU = AMD FX-8350
Cooler = Corsair H100 Liquid Cooling Kit w/ Corsair SP120 High Performance Fans
Was about to start OC but noticed under stress test in Prime the socket temps were getting up to 52 degrees while the core was only 33....
that is a big difference considering the socket temps should only be 5-10 degrees difference right?
I have already removed the H100.. cleaned off the Thermal paste and re-applied it. tightened as far as I could get by hand.
CPU = AMD FX-8350
