Hello,
My pc performs realy bad in games, as title says.
I read tons of threads about similar problems but they are usualy about bad game optimisation or bad engine or bottleneck.
In CS:GO my cpu is around 20-40% of total usage, first core is usualy around 50-80 sometimes barely touches 90, other cores are running pretty low, so bottleneck shouldnt be the problem i would say. Gpu usage is usually around 20-30%. Temperatures are totally ok (cpu around 45, gpu around 55). Im getting around 100-120 fps while i should be getting like 300-400 my gtx 1070ti
In other games it is basically almost the same, in some even worse with gpu usage around 5-15%.
I tried reinstalling gpu and chipset drivers, didnt work.
I have read in one thread that this could be due to wrong bios settings but I didnt realy find what settings. Or could be caused by defective mobo.
I tried to flash bios then, downloaded the windows version. Started the .exe file and after the PC shut down it Beeped twice instead of updating bios. Then the windows started normally. I've read that should be Parity circuit failure, which should be defective mobo or memory.
Does anyone know what could help me please? Should i try to "complain" the mobo? ...I dont know if I translated this word "complain" correctly, bysically i men the thing that you send defective goods back to dealer in order to get functional, sorry for my bad english.
PC specs:
- Msi 1070ti armor
- R3 2200g ( i know it is weak for this gpu ...even so, it isnt bottlenecking the gpu atm and if it would be, i still would get much more fps, and i plan to upgrade to 2600 soon)
- Asrock fatal1ty x470 gaming k4
- two sticks of Crucial ballistix 8gb ddr4 3000
- Evga supernova 650 g3
Thank you for all ur responds.
PC specs:
- Msi 1070ti armor
