Hello,
I posted here recently about some issues I've been having with my CPU. Specs:
CPU : Ryzen 7 1700
GPU : EVGA GeForce 1060 6GB SSC
Mobo : MSI B350 Tomahawk ATX Am4 Motherboard
Memory : Corsair Vengeance LPX 2x8GB DDR4 DRAM 3200MHz
Cooler : Corsair H60 Liquid
PSU: EVGA 650W W 80+ Gold Certified Semi-modular ATX Power Supply
Running a stable overclock at 3.9GHz / ram at 3000Mhz.
When I open task manager to view the load of my CPU vs GPU while playing games, I noticed that my CPU is only working at around 15-25 % (the actual game using only 10-20%), while my GPU is almost maxed, around 80-100%. I've tested this over multiple games, with the same results.
A few details:
-My CPU is not running too hot. I know this would be the cause of this issue as I have done some research before posting here. But the CPU only ever hits 60-70c max.
-Case is clean of dust, airflow is good
-I did a clean install of windows just 2 weeks ago
-I have all the latest GPU drivers and BIOS version
-performance in games is OK, but I feel could be better if the CPU was working to full potential
Does this mean my CPU is being "bottlenecked"? Or is this normal for multi-threaded CPUs with a lot of cores?
Any help is appreciated!
CPU : Ryzen 7 1700
A few details:
