Low disk read/write capability and performance on my Acer laptop
ZayulRasco
Commendable
Dec 8, 2016
Recently I was in the middle of a game on my Acer Aspre V3-771G and my fps plummeted. I went to go check task manager and my disk usage was at 100%. I checked performance monitor and system seemed to be using the most read/write.
I disabled superfetch, prefetch, and windows search, made sure I didn't have a secondary antivirus installed, changed my pagefile settings, restarted several times, ran a chkdsk /r, and did a clean boot, and my disk was still always at 100%. The thing taking up all my disk activity was always just the most demanding application I had open, and oftentimes it's usage was very low, even though task manager listed it as using 80%+ of my disk.
Finally I used microsoft defragging service, and that made the disk usage drop to normal when not launching an application. Ever since then, my disk performance has been very slow. My disk takes a very long time to download games and applications. It's usage always spikes to 100% whenever I launch an application, even a simple one like mumble. I downloaded Defraggler, and am currently attempting to defrag my disk again (my disk is still 22% fragmented according to Defraggler.), which is apparently going to take >1 day. Defraggler and crystal disk service both say my disk health is good. I would hugely appreciate any advice!
Edit: Here is some data
CrystalDiskMark 5.2.0 x64 (C) 2007-2016 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 122.897 MB/s
Sequential Write (Q= 32,T= 1) : 114.217 MB/s
Random Read 4KiB (Q= 32,T= 4) : 0.678 MB/s [ 165.5 IOPS]
Random Write 4KiB (Q= 32,T= 4) : 0.879 MB/s [ 214.6 IOPS]
Sequential Read (T= 1) : 117.869 MB/s
Sequential Write (T= 1) : 116.603 MB/s
Random Read 4KiB (Q= 1,T= 1) : 0.376 MB/s [ 91.8 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.884 MB/s [ 215.8 IOPS]
Test : 1024 MiB [C: 27.6% (257.0/931.0 GiB)] (x5) [Interval=5 sec]
Date : 2016/12/08 20:46:20
OS : Windows 8.1 [6.3 Build 9600] (x64)
Hello... How full is it? Typically laptops can have 5400 RPM platters VS 7200 RPM drives... Yes defragging will help arrange the data back together and should be done on platter drives... shut off/reduce page file before you do this too will help the file arrangement... and then turn back on.
HDD's are typically the slowest data port on a Computer... adding a small/low cost OS SSD (60gb-120gb) would help yours or anybody's system a lot. B /
Currently at 256 used/674 free. It's a 7200 RPM drive. Currently it is much slower than before the issue with 100% disk usage.
