Hello,
Over the last month or two I have noticed how my draw distance in several games suddenly got reduced. The textures only load when I get close to them and I can see how they fade away each step I take. Other textures turn into looking like a blurred low texture surface the further away I walk.
Games where I suffer this problem.
GTA V,
Skyrim,
GTA SA (SA-MP)
CS:GO
That means 4 different games with 4 different game engines, which means the games are not to blame for this issue.
What I have tried to do on my own:
Turn off crossfire,
Tried different Crimson settings in the control panel,
Updated to different graphic drivers,
Reinstalled drivers with Driver Sweep and CCleaner.
Rerolled to older drivers back in 2015,
Reinstalled Windows 10
Reset overclocks and remove MSI Afterburner efter reinstallation of Windows 10.
Tried Radeon Pro and increase texture lod and minimap textures.
None of these methods worked for me and I am still suffering the same issue, I really need to get some tips on how to fix this problem. I have seen others have similar problems however none provided a proper solution to the problem.
Otherwise all games run well, no crashes and with proper FPS, the textures look great when they actually load in close distance.
Greatful for any help,
Thomas
My computer:
Motherboard: Asrock Extreme4 Z77 ATX | CPU: Intel Core i7 3770K 4.6 GHz | GPU: x2 Sapphire R9 290x Tri-X Crossfire | Power Supply: XFX 850 watt 80+ Bronze | Memory: Crucial BallistixSport 16GB 1600MHz | Storage: 1TB Seagate Barracuda + 840 evo SSD 250gb | Monitor: Qnix QX2710 96hz + Asus 1080p 144hz|
GTA V,
Skyrim,
GTA SA (SA-MP)
CS:GO
Turn off crossfire,
Thomas
My computer:
