G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Hello everyone,
I'm rather confused over something I was told today.
Low-end PC power supply units always dissipate whatever power they are
rated for, e.g. a 400W PSU will always dissipate 400W whether the system
is idle or not. If the system does not need the power, then that power
is dissipated as heat (?!?). That would make the power saving features
on modern CPUs almost moot, no?
Is it true? Are PSUs, even cheap ones, able to provide whatever power is
needed up to the limit, or do they always crank out the max?
Regards, Grumble
Hello everyone,
Regards, Grumble
