Hello!
I have a tp link WR1043ND gigabit router and I can't use the full 1gb on speed tests. It stops at 300mbps. I use a cable to connect it (not wifi), and in my network connections in control panel says that the speed is 1gbps with full signal. My network cards supports gigabit speed. I have an Asus Rog G750JW and the maximum speed stops at 300mbps on speed tests. Isn't it supposed to rise until 1000mbps?
Thank you!
Thank you!
