Hi,
I have a PC(wire) and a MacBook Pro(wifi) connected to my router(Binatone). I tried transferring files between the two and I got 3 MB/s in wifi and 8 MB/s using cable. Then I used a crossover Ethernet cable and connected my MacBook Pro directly to the PC and the results was 28 MB/s. I tried disabling firewall in the router and the result was the same. I don't understand where the bottle neck is. Is there any settings in the router which I should change to increase the speed?
Thanks,
Akbar
Thanks,
Akbar
