Question Low fps 4060TI
8
Hi.
I nearly bought RTX 4060 TI and my previous graphic card was 1660TI. Since I use 4060TI I experienced low fps and drop fps on my system even when I update my drivers and reinstall drivers. My system is:
Core I5 12400F , RTX4060 TI, 32G RAM.
I try hard in Nvidia control panel but nothing has changed. I will be pleased if you show helpful.
Hi.
cpu ( temp)
gpu brand also (temp)
psu
and resolution your trying to play at.
cpu cooler ?
temp when pc is idle and when pc is gaming i would suggest
hw monitor
https://www.cpuid.com/softwares/hwmonitor.html
Download hwinfo and run it in sensors only mode.
Launch a game and play it for a few minutes.
Take a screenshot of the hwinfo page while the game is running and post here please.
Also define what is "low fps" ... you won't get 120 fps @ 4k on a 4060 in most modern games!
Ok I'll do that but I run on 1080p and on CS2 I have to get 200 fps on high graphic but it gives me 90-120
Looking at
https://www.notebookcheck.net/Counter-Strike-2-in-review-laptop-and-desktop-benchmarks.767018.0.html
Your FPS are relatively similar to those benchmarks.
P0.1 = 0.1% lowest fps
P1 = 1% lowest fps
NVIDIA GeForce RTX 4060 Laptop GPU, R9 7940HS
Razer Blade 14 Mid 23
194.6 (50min, 75.5 P0.1, 85.7 P1) fps
162.3 (31.9min, 54.3P0.1, 81.2 P1) fps
139.1 (20.5min, 37.6 P0.1, 66.1 P1) fps
The averages look high but a 20 fps minimum on high graphics would be quite jarring!
Reactions: Roland Of Gilead
