[SOLVED] Low FPS Above recommended specs
Mar 24, 2020
6
Hello,
I have the above recommended specs for warzone on call of duty modern warfare, however I am getting 20 fps, can anyone help?
My Specs:
GTX 1660TI
16GB RAM
Intel i5-7600
Recommended Specs:
NVIDIA GeForce GTX 970 / GTX 1660 or Radeon R9 390 / AMD RX 580
12GB RAM
Intel Core i5-2500K or AMD Ryzen R5 1600X processor
Thank you.
Mar 24, 2020
6
The problem was with my CPU temperature, it was above 80 (almost reaching 100), new cooler fan sorted the problem. Thank you everyone for the help!
Nemesia
Make sure you're playing with your 1660TI and not the Intel® HD Graphics 630 from your motherboard. Is your monitor plugged on your GPU and not the onboard graphics?
Go into the Nvidia Control Panel -> 3D Settings. In the global section or the individual profile make sure that your prefferred graphics processor is your high performance graphics processors and not the integrated graphics.
If you don't see the choice in the Nvidia Control Panel try looking in your Intel® HD Graphics 630 control panel.
Mar 24, 2020
6
CPU usage is roughly about 30%, Memory usage is about the same, GPU usage is minimal, I'm not sure how to check the cpu/gpu temp, and not sure sure how to check the ssd usage, the system is fine when I used malware yesterday.
Mar 24, 2020
6
