CPU: Intel I5 3470
GPU: Biostar RX 560 4gb (Graphics clock 1175 MHz, Memory clock 1500 MHz - OC to 1353 MHz and 1900 MHz) - No 6pin connector
RAM: Kingston 2x4GB 1600 MHz
HDD: 750GB
PSU: 450W 80+ bronze
Monitor: Benq gl2450hm FULL HD 60Hz
Motherboard: Fujitsu d3161-a12 gs 3
I recently bought a new PC with these specs.
I even tried to OC the GPU to boost performance but it was still very bad.
I get lower FPS than on my old GTX 660 card with I5 2500.
Example: CSGO went from 250FPS to 180FPS, GTA V was playable on High settings, now it stutters sometimes at Low, Steep was playable at medium/high, now it is totally unplayable, Heroes and Generals went from100 FPS on Ultra to 60FPS on Low...
I sometimes see my GPU throttle from 100% usage to 0% usage, immediately back to 100% and again down to 0%...
After i OCed my GPU, that is less frequent but the FPS is still bad. (when it throttles like that, it stutters, but when it doesn't it just has a constant low FPS)
I was searching online for a solution because I don't believe the GPU is that bad, my old GTX 660 is miles better.
I updated my graphics card drivers.
I saw someone mention that they updated the BIOS and it did wonders for them, they had the same problem and i put the GPU in the old PC with I5 2500 and the performance was almost identical. (that build had a better Gigabyte motherboard so that rules out that it is an outdated BIOS problem or bad motherboard)
I am sick to my stomach because the PC shop that sold it to me isn't fulfiling their part of the deal and they won't give me a replacement, so I'm all out of money and nobody to help me.
I fiddled with the AMD Software settings and put it up for "High Performance".
The same guy that said he updated BIOS and fixed it, also said that he found a "Load Performance button" in his BIOS, clicked that also, but I can't find that in my BIOS.
My temperatures are OK I think:
https://ibb.co/Bjx8bjg
GPU is always under 70 degrees while gaming
CPU is always under 73 degrees while gaming
I tried stress testing and look at this ----> https://ibb.co/TKpFSsG
It says I have a RX 460
The official AMD Radeon software says it is a 560 and I have the box of the GPU, it's a 560 4GB Biostar,
3DMark test, fails after a minute or two, probably unstable clock, but it runs fine in games. https://ibb.co/F5SsyzJ EDIT I tried it without the OC, it still fails on the same spot.
EDIT I got this Directx11 RDMark test to run, the previous Directx12 crashes:
https://ibb.co/xDJMfr0
https://ibb.co/mDTMJMn
(These 4 links are all the parameters monitored)
https://www.3dmark.com/3dm/57352731
HDD: 750GB
