[SOLVED] Low fps and texture resolution in vr
HadMatter
6
I know you guys are probably sick and tired of noobs begging for help. Well I'm sorry to say I'm about to be one of them. I really have tried to research this on my own, but I've hit a wall and I'm starting to lose my mind. I've never delved into fine tuning gpu settings before. If a game started sputtering I'd knock the game's graphics presets or resolution down a rung or two until it stopped. That was fine for me until I purchased a VR headset.
I'll try to make this concise so I don't waste your time. Below you'll find my system specs, my efforts so far, and anything else I think might help. I really appreciate any assistance or advice on where to go from here. Thank you so much.
System specs (nothing overclocked):
  • EVGA GeForce RTX 2070 SUPER BLACK GAMING
  • Intel Core i7-9700K Coffee Lake 8-Core 3.6 GHz (4.9 GHz Turbo) LGA 1151
  • G.SKILL TridentZ RGB Series 16GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200
  • Intel 660p NVMe PCIe M.2 1TB (game is installed on this)
  • ASUS ROG Strix Z390-E Gaming
  • Antec True Power Quattro-850W psu
  • Windows 10 pro 64bit (yes, used Media Creation Tools to create bootale USB to clean install)
  • BIOS Version 1704 x64
  • Oculus Quest 2
Efforts so far:
  • latest gpu driver is installed
  • I ran UserBenchmark and here are my results
  • running fpsVR, I'm seeing the following gpu readings:
    • fps usually in the 20 - 30 range, with dips into single digits
    • temp 70 degrees C
    • 90%+ power consumption or perhaps max load
    • SteamVR SS 150% (I know SS is super sampling, but I haven't figured out exactly what the number means yet)
    • Reprojection Ration ~50% (whatever that means)
  • in Nvidia's control panel I turned off Anistropic (sp?) Filtering, Anti-Aliasing, and set power management mode to 'optimal power' (I've since been trying other recommended settings to no effect)
  • no other extraneous apps are ever running
  • I just performed a clean install of Windows, so there shouldn't be any digital flotsam gumming up the work
  • The readings I've posted were all taken while playing No Man's Sky VR, but I got similar readings in Fallout 4 VR as well
  • For the record, I've tested a couple of non vr games and am able to sustain fps in the 100s. At first I thought maybe vr is just that much more taxing on a card and this is what normal performance looks like. But then I saw a No Man's Sky benchmark video using a 2070 super getting fps in the 100s.
Your specs are half mentioned. Make and model of your motherboard? Make and model of your rams? Make and model of your PSU? Version for Windows 10? Did you use Windows Media Creation Tools to fabricate your bootable USB installer? What BIOS version are you currently on for your motherboard?
Reactions: Unolocogringo
Sorry, I updated my system specs list. When you mentioned bios version it made me think that was something I haven't updated, so I'm going to look into doing that now.
........ annnnd done. But it didn't change my situation.
Latest posts
