Hi, this is my rig I've had for a year, built by PCSpecialist.co.uk:
CPU: AMD FX 6200 @ 3.8 GHz (stock)
GPU: Powercolor HD 7870 (stock) w/ Aftermarket CPU cooler, Titan 'Super Quiet 22dBA Cooler'
MB: ASUS M5A97 R2.0
PSU: Corsair TX 650 (I've noticed an odd coil whine, corresponding to movement of the mouse.)
RAM: 8 GB Kingston Hyperx 1600 MHz
HDD 500 GB WD Green
Monitor Res: Main - 1360x768 (I prefer to play widescreen), Secondary 1600x1200
My problem is that I drop frames even when my CPU & GPU usages are low. This problem has persisted the entire time I have owned this rig.
Here are some examples:
CPU 42% in Saints Row 3, GPU always below 50% - FPS is always changing, ranging from 130 indoors to 10-70 outside.
GTA IV EFLC has similar performance, CPU bumps up to 50 occasionally, but GPU stays at around 40 - FPS varies massively from 10-70, changing graphics settings seemed to have little effect on it.
Garry's Mod CPU was 16%, and GPU 19%, frames varied from 50-180, generally around 80-100.
TF2 CPU was 37%, GPU was 19% mostly, FPS was 45-80 unless standing alone inside, in which case it when up to high 180s. Have to play on Medium/Low Settings. 🙁
Basically, in all games, FPS is never stable.
Also, FPS seems to decrease drastically when looking into the distance on any game, I'm not sure whether this is normal.
This has puzzled me for a long time, and has led to me not gaming much on this rig at all. Surely I should have higher usage and therefore higher FPS? Is my CPU bottlenecking my GPU? Are some parts broken D:? Do I need to change some BIOS settings? Help!
Thanks for any response in advance, all help is appreciated. If you need any more info just ask me!
MB: ASUS M5A97 R2.0
HDD 500 GB WD Green
