Question LOW FPS- CPU UPGRADE???
Nov 19, 2021
17
Hi guys. So I am 100% getting lower fps in almost all games than I should be I feel
i5 10400f
32GB ram
3060ti founders edition
2.2 SSD 1TB
650W
1TB HDD
I was looking at upgrading my cpu to an i9 but everyone else seems to say that it shouldn’t need upgrading
Nov 19, 2021
17
UserBenchmarks: Game 98%, Desk 82%, Work 88%
CPU: Intel Core i5-10400F - 81.9%
GPU: Nvidia RTX 3060-Ti - 127.2%
SSD: Microsoft Storage Space Device 1TB - 218.4%
HDD: Seagate Barracuda 1TB (2016) - 80.2%
RAM: Corsair Vengeance LPX DDR4 3600 C18 2x8GB - 36.5%
MBD: MSI Z490-A PRO
Nov 19, 2021
17
UserBenchmarks: Game 106%, Desk 84%, Work 97%
CPU: Intel Core i5-10400F - 87.4%
GPU: Nvidia RTX 3060-Ti - 128.4%
SSD: Microsoft Storage Space Device 1TB - 225%
HDD: Seagate Barracuda 1TB (2016) - 98.2%
RAM: Corsair Vengeance LPX DDR4 3600 C18 2x8GB - 40%
MBD: MSI Z490-A PRO
this is with nothing run running
MBD: MSI Z490-A PRO
Can you share the link to the results, it gives more information. Immediately though it looks like your RAM is running at stock speed and not 3600mhz. Turn on XMP in the BIoS.
Elezondo
Commendable
Nov 19, 2021
38
18
1,535
Several things:
  1. Your computer has been up for 2.6 days, unless you need it running all the time you should restart/shut down occasionally. You have higher than ideal for idle Background CPU usage. You should restart and then rerun the benchmark.
  2. Your OS drive is a HDD
  3. Your memory is rubbing at 2133, you need to enable XMP, if it fails select a lower profile until you find a stable settings.
  4. What case and CPU cooler are you running?
Nov 19, 2021
17
Several things:
For some reason when I shut down my PC it goes into a mode where the power button is still lit. Kind of like a sleep mode for some reason. But the fps issue isn’t exclusive to recently. I have now enabled xmp and it has boosted my fps quite a bit I won’t lie. I also cleaned the pc also.. I just need to switch my OS to ssd now
