Low fps CS:GO GTX 960 + i7 5820k
Slinix
15
I'm getting absurdly low frames on CS:GO with my GTX 960, whenever I join a casual game, my FPS stays about 60FPS - 150 on the lowest settings possible. My question, is there a fix to this? Is this normal? I am getting worse frames than my old Radeon HD 5870.
Does it do this playing offline? I assume you are playing at the same resolution you were when you had an HD 5870?
No, it's fine in offline and in community servers.
Well it sounds like a game or lag issue then rather than bad hardware. You could try this: https://www.youtube.com/watch?v=rXDrH8bUuwk.
Some more stuff here: http://www.dcgaming.org/set-up-your-csgo-like-a-pro/
