Low Fps CS:GO
posotikh
Hello,
CPU : i7-4790 @ 3.60 GHz
GPU : Gigabyte G Force GTX 970
MOTHERBOARD : GIGABYTE Z97N - WIFI
RAM : 8.00 GB
As you see, my gear is more than average and i can not get a stable 300 fps. I usually play with 200-220
What should I do to boost my fps?
If it's bothering you, Just cap the FPS to 121 in the console through the FPS_MAX (Or was it max_fps?) and set net_graph to 0 to prevent your OCD from destroying your experience. CS:GO should be as smooth as butter right after that.
