Question Low fps from 3060ti
Mar 10, 2023
6
Hey guys, I’m really struggling to figure out why my fps is so bad, I’m barely getting 165fps on performance mode on Fortnite, I’ve updated my gpu driver but it didn’t help. My old pc which is a 1660ti is pulling better fps
This is my new specs
Operating System
Windows 10 Pro 64-bit
EI CPU
Intel Core i7 6700 @ 3.40GHz 26 °C L
Skylake 14nm Technology
UI RAM
32.0GB Dual-Channel DDR4 (15-15-15-36)
IE Motherboard
ASRock Z170 Gaming K4 (CPUSocket) 31 °c E
• Graphics
LEN G25-10 (1920×1080@144H2)
4095MB NVIDIA GeForce RTX 3060 Ti (Dell) 39 °C E
5] Storage
953GB Patriot M.2 P300 1024GB (Unknown (SSD))
Make and model of your PSU and it's age? As for the motherboard, what BIOS version are you currently on? What GPU were you working with prior to the RTX3060Ti in this platform?
my psu is a CX750M
I don’t even know about the bios, how do I check? And my old gpu was a 1660ti GeForce
Age of the unit? The grey labelled CXM unit or the green labelled unit? Hmmm, the last BIOS for that motherboard. Did you run DDU prior to removing the GTX1660Ti from your build? Once the RTX3060Ti was populating the slot, did you manually install the latest GPU drivers in an elevated command, i.e, Right click installer>Run as Administrator?
I just bought it off someone so I’m not sure of age. It’s a grey one, I just did a express installation
I
I have an i5 9400F would that fix it by putting that in? I think the one in it now is 4 cores and the i5 is 6
