LOw fps,graphic card.
salata1500
11
Hello, i have a hp slimline s3400f computer and i have bought CS GO and it lags really bad even on minimum resolution and textures.Is there any way for me to get more fps or do i have to change my graphics card or my ram to ddr3 cause i have ddr2.BTW i can only have 180 volt graphic cards. Any help so i could play CS GO witch doesnt have high requierments.Thank you very much for help.
maxalge
Champion
Ambassador
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374065&cc=us&dlc=en&lc=en&product=3688725#N332
Is this your computer?
salata1500
11
yes this is my computer. would these work with my computer good.which one is better.Will it lag with bf3, cs go:
http://allegro.pl/karta-graficzna-asus-nvidia-geforce-210-1gb-pci-e-i2888753543.html
http://allegro.pl/gigabyte-geforce-210-512mb-ddr3-64bit-dvi-hdmi-i2846845724.html
one has 1gb and the second 512 mb but the 512 has better mhz.thanks for help
maxalge
Champion
Ambassador
Sadly your computer only has 160w power supply.
You will need to update that first, before you add any discreet graphics cards.
salata1500
11
How do i update it? is it hard? Are there any tutorials ? after i update it will that graphic card work well? are there any good geaphic cards for 160w?
maxalge
Champion
Ambassador
Sorry no, no discreet power supply that runs on less than 300w.
Yes after you update your power supply you can get a good graphics card.
http://www.youtube.com/watch?v=b18TiKbdB2I
To better help you, you can list your maximum budget and your location/websites you want to shop, and I am sure people will help you decide the best way to get those games running.
salata1500
11
will all the power supplys work with hp slimline?? Could you give me a couple of links /sites with good power supply?Thanks.
salata1500
11
You will need a "Flex ATX Power supply" you will be limited to power size... but you can get up to 400 watts I see... search Flex ATX power supply for your store selection.
4 Gig of ram is good... powersupply and budget for a graphic card.
maxalge
Champion
Ambassador
maxalge
Champion
Ambassador
Yeah getting at least 400w would be a good idea. That opens up more powerful GPU options.
