Low fps in Arma 3 with high end pc
dawgx
63
My fps in arma 3 is locked at 20-30 no matter what i do. even lowest graphics will keep the fps like that. Here are my specs if interested.
Note : CPU usage stays at 9% when im ingame and GPU stays at 1%
-CORSAIR Carbide SPEC-03 Case
-AMD RYZEN 7 1700 Processor
-ASUS PRIME B350-Plus Motherboard
-HYPER-X Fury 16GB DDR-4 2400MHz Memory
-WD 1TB Blue 7200RPM-HDD
-ASUS GTX1070 Dual OC 8GB DDR-5 Graphics Card
-ZALMAN ZM700LEII 700W Power Supply
Is the games and windows legit?
Yes, even many other people with high end pc's have this problem but non of the solutions work for me.
Is this with mods? I have experienced ARMA 3 to run incredibly slow with certain mods installed. ARMA 3 seems to favor strong single core performance and strong memory performance. There is an optimised memory allocator that did not help me one bit. Changing graphics around made 0 difference basically, the only settings that helped was render distance. I struggled quite a bit with my i7 3770 and GTX 1080 at the time, and just stopped playing it completely in the end. How does PUBG run for you? Does that run well? Just to feel if something is wrong with the setup maybe.
https://forums.bohemia.net/forums/topic/202527-we-need-amd-ryzen-benchmarks-share-your-toughts/
render distance improved the gameplay by 3-5 fps, and PUBG runs perfectly at 80-110 fps all graphic settings maxed out, its just arma, the only game Im having problems with
