Low FPS in Crysis? Help
wonderingwhatis
161
First let me give you the specs for my system (homebuilt)
650 watt Antec NeoPower, PSU
Asus P5E <Green> X38 chipset, mobo
2GB Gskill 4-4-4-12cl, ram
Visiontek ATi Raedon HD 4870, GPU
Intel E6750 @ 3.0Ghz, CPU
WD Raptor 10,000rpm 150GB, HD
I didn't know where to post this so I apologize if it is in the wrong section.
I recently upgraded video cards from an 8800GTS to the 4870 in hopes of getting smooth playability in crysis with good settings.
With the old 8800 @ 1920x1080 the game is completely UNplayable and was pretty much a slideshow.
Also with the new ATi card I decided to do a fresh install of Vista Ultimate 64, to start clean :)
So first problem is with the ATi Card Crysis will not even give me the option of 1920x1080 (which I was able to select with the nvidia), its highest resolution is 1770x1000. I have tried all the Catalyst drivers and none seem to remedy this; as well as all the crysis patches.
Anyway with my rig I figured it would be playable on high at 1920x1080; but I'm running it at 1680x1050 on medium settings to get a smooth framerate. I can crank the settings to high but if any action happens it will lag pretty badly and is not smooth.
So my two initial questions are:
1.) Has anyone had this problem with crysis not showing your screens native resolution and is there a fix?
2.) Should I be able to run this game on high settings at 1680x1050 smoothly or was I reaching too far?
Now to (hopefully) remedy the situation I just ordered 4 more GBs of ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231192
And I also ordered a QX6850 From intel (they have a purchase program for retail sales where the cost is $240).
Will these two upgrades enable me to run the game at max settings and resolutions? Or will I need to go crossfire with a 4870x2 in addition to my 4870?
Thanks for your responses in advance!
dagger
Splendid
Mar 23, 2008
5,624
2gb ram will be a problem. Crysis alone can hog 2+gb after a while of gameplay. Although e6750 shouldn't bottleneck, and the qx6850 is overkill.
The resolution seems to be a driver issue. Try a modified driver and see if it helps.
http://downloads.guru3d.com/DNA-ATi-8.6B-for-Vista-download-1986.html
Run driver sweeper after uninstalling old driver and reboot, before installing new driver.
http://downloads.guru3d.com/download.php?det=1655
This shows the fps you should be getting in Crysis, at high settings.
http://www.techpowerup.com/reviews/Diamond/HD_4870/8.html
jimmysmitty
Champion
18,741
12
58,165
975
^He got the QX6850 for $240 dollars. Thats not bad at all. At that price with the unlocked multi its a steal.
Other than that what the previous guy said and make sure that 16:9 is the ratio selected.
rodney_ws
Splendid
Dec 29, 2005
3,819
17
Simple solution... just switch to playing Wolfenstein 3D. Problem solved. It's the same thing as Crysis... you just run around and push buttons and shoot crap. I imagine you'll probably get around 2500 fps once your quadcore comes in.
jimmysmitty
Champion
18,741
12
58,165
975
^LMAO!!!!!!!!
Forget that, go to Decent: Destination Saturn. I tried that on my old system with a P4 EE 3.4GHz and a x850xt and it was so fast that I barely tapped a button and I went flying through the level. Damn non frame limited games.
IH8U
1,612
41
That is funny, but I always preferred Fallout, and the original CoD, and MoHAA. (maybe I'll try to find my copy of Baldurs Gate II tonight)
wonderingwhatis
161
Hmmm maybe my version of crysis is broken; it is lacking these buttons you speak of :(
And I prefer Doom for my button pushing and key hunting.
I tried the modified drivers after running the driver cleaner; and they didnt fix the problem. I can run every other game @ 1920x1080 but crysis just lacks that option. I suppose it is not really a problem anyway as my rig can't even run the game at lower resolutions.
gerardfraser
16
I have a fix for your res.
Here is also a cfg file for your game crysis for very high settings and playable FPS with that card
OK if you just want 1920x1080 put in these numbers in a cfg file and place it in your crysis game folder or you can enter them in the game console by hiting thr ~ key
con_restricted=0
r_displayinfo = 1
r_width = 1920
r_height =1080
Code:
con_restricted=0
r_displayinfo = 1
r_width = 1920
r_height =1080
 ;Slowmotion by Addi
bind q time_scale .3
bind 3 time_scale 1
q_ShaderPostProcess=2
e_terrain_ao=1
r_HDRlevel=.5
r_ssao_amount=0.2
r_SSAO_darkening= 1.8
r_GeomInstancing = 1
r_MultiGPU = 1
r_ShadersAsyncCompiling = 1
e_particles_thread = 1
con_restricted=0
e_cull_veg_activation=50
ca_AttachmentCullingRation = 150
ca_DrawFaceAttachments = 1
ca_UseDecals = 1
e_cbuffer_resolution = 128
e_clouds = 1
e_decals_allow_game_decals = 1
e_decals_life_time_scale = 1
e_detail_materials_view_dist_xy = 4096
e_detail_materials_view_dist_z = 128
e_dissolve = 0
e_foliage_wind_activation_dist = 30
e_gsm_cache = 1
e_gsm_lods_num = 3
e_gsm_range = 5
e_lod_min = 2
e_lod_ratio = 5
e_max_entity_lights = 5
e_max_view_dst_spec_lerp = 0.5
e_obj_quality = 2
e_particles_lights = 1
e_particles_lod = 0.75
e_particles_max_emitter_draw_screen = 16
e_particles_object_collisions = 0
e_particles_quality = 2
e_phys_foliage = 2
e_phys_ocean_cell = 0
e_proc_vegetation = 0
e_ram_maps = 0
e_shadows = 1
e_shadows_cast_view_dist_ratio = 0.85
e_shadows_from_terrain_in_all_lods = 0
e_shadows_max_texture_size = 1024
e_shadows_on_alpha_blended = 0
e_sky_type = 1
e_sky_update_rate = 0.75
e_terrain_normal_map = 0
e_terrain_occlusion_culling_max_dist = 115
e_vegetation_min_size = 0.8
e_vegetation_sprites_distance_custom_ratio_min = 0.6
e_vegetation_sprites_distance_ratio = 1
e_vegetation_use_terrain_color = 1
e_view_dist_ratio = 50
e_view_dist_ratio_detail = 30
e_view_dist_ratio_vegetation = 40
e_water_ocean_fft =1
e_water_ocean_soft_particles = 0
e_water_tesselation_amount = 6
e_water_tesselation_swath_width = 6
es_DebrisLifetimeScale = 0.8
es_MaxPhysDist = 75
es_MaxPhysDistInvisible = 12
g_battleDust_enable = 1
g_breakage_particles_limit = 250
g_joint_breaking = 1
g_ragdollDistance = 40
g_ragdollMinTime = 15
g_tree_cut_reuse_dist = 0.6
i_lighteffects = 0
i_rejecteffects = 1
p_max_MC_iters = 4500
p_max_substeps_large_group = 4
p_num_bodies_large_group = 60
r_Beams = 3
r_BeamsDistFactor = 0.75
r_BeamsMaxSlices = 16
r_ColorGrading = 0
r_DepthOfField = 1
r_DetailDistance = 2
r_DetailNumLayers = 0
r_DetailTextures = 1
r_DynTexAtlasCloudsMaxSize = 32
r_DynTexAtlasSpritesMaxSize = 32
r_DynTexMaxSize = 80
r_EnvCMResolution = 1
r_EnvTexResolution = 3
r_EnvTexUpdateInterval = 0.08
r_FillLights = 0
r_FSAA = 0
r_FSAA_samples = 0
r_HairSortingQuality = 0
r_HDRRendering = 2
r_PostProcessEffects = 1
r_MotionBlur = 4
r_Flares = 1
r_UseEdgeAA = 0
r_colorgrading = 1
r_GlowScreenMultiplier = 0.2
r_WaterGodRays = 1
r_sunshafts = 1
r_ImposterRatio = 1.5
r_LightsSinglePass = 0
r_MotionBlur = 0
r_ShadowJittering = 1
r_ShadowBlur = 1
r_ShadowsMaskResolution = 0
r_SSAO = 1
r_SSAO_quality = 2
r_SSAO_radius = 2
r_texatlassize = 2048
r_TexBumpResolution = 0
r_TexResolution = 0
r_TexSkyResolution = 1
r_TexturesFilteringQuality = 2
r_UseEdgeAA = 0
r_UsePOM = 1
r_UseSoftParticles = 1
r_WaterCaustics = 1
r_WaterReflections = 1
r_WaterReflectionsQuality = 2
r_WaterRefractions = 1
r_WaterUpdateDistance = 0.015
r_WaterUpdateFactor = 0.003
sys_flash_curve_tess_error = 6
sys_flash_edgeaa = 1
sys_LowSpecPak = 1
q_ShaderTerrain=2
q_ShaderPostProcess = 2
q_Renderer = 3
v_vehicle_quality = 4
g_dof_ironsight = 1
r_motionblur = 1
g_dofset_maxscale = 1
g_dofset_minscale = 1
e_terrain_ao = 1
r_TerrainAO = 7
r_TerrainAO_FadeDist = 5.3
e_terrain_lod_ratio = 1
e_terrain_texture_lod_ratio = 1
r_TexturesStreaming = 0
gamerk316
Glorious
Jul 8, 2008
12,681
528
Theres 3 ways to play Crysis:
1980x1080 with everything very high, but low framrates.
1980x1080 with medium/high settings, but with lower quality
1600x1200 (or even 1280x1024) with everything max, slight detail decrease but all extra visuals intact.
I spend $4500 on my PC, and even I won't touch Crysis above 1280x1024. Why people don't bump the game down to playable levels is beyond me...
jimmysmitty
Champion
18,741
12
58,165
975
Cuz they want the uber pretty. Hell I play HL2 and TF2 @ 1280x1024 even though I can play it on my 40" TV @ 1920x1080p but I like the smaller screen that doesn't kill my neck.
gerardfraser
16
Well guys if you do not use the power of the video cards at higher resolution.Then you just waste your money.I can tell you for a fact that CRYSIS is very good on my system at 1980x1080.
Anyway the post was to tell himhow to play at 1920x1080 thats all
Benchmark of CRYSIS
gamerk316
Glorious
Jul 8, 2008
12,681
528
I play competitvly, as such, any type of lag is unacceptable. I have my settings set up for 45-60 FPS on Crysis, and did it primarily by lowering the resoultion to 1280x1024 (with a few minor changes to the .cfg file).
And as for the "taxing the GFX card" argument, whats the point of high settings if things go so slowly you spend time on this forum asking how to get more settings instead of playing the game?
gerardfraser
16
Well for me its good,did you even look at the screenshot,
anyway I play at 1920x1080 with POM,DOF,Motion blur and blah,blah ,blah,
at 57fps AVG from the bench and 35 min frames,for me its all I need.
I am sure others would love to be able to play like that.
jimmysmitty
Champion
18,741
12
58,165
975
^And I am sure people would like to have a high end system like that.
Either way Crysis is still horribly optimized. Maybe the next one will be better.
wonderingwhatis
161
Thanks again for the input.
With the .cfg settings I was able to max out the reolution.
I Also OCed my 4870 to 1100mhz on the ram and 980mhz on the gpu and it seems to be running slightly smoother.
Again hopefully the ram and the QX6850 help SLIGHTLY.
Unfortunately I cant OC my 6750 anymore with it being stable. When the CPU was first setup my brother OCed it to 3.8Ghz and ran the VCore up to 1.55!! He ran it like that for weeks and now it just BSODs if i really try to OC it.
snipingkid
125
Hey everyone.
I'd like to help fixing crysis, you see, I haven't been prompted to install an update, hotfix, or patch when I installed my game. I remember downloading something from microsoft on my prior crysis install.
I just got a 9800GX2 and Crysis just doesn't run on it. I tested it on XP with my old rig (E6600, 4gb Corsair DDR2-800, P5B Deluxe), and got 56.87 fps (1680x1050, high, full AA) in the crysis island benchmark. I'm thinking that this is a DX10 problem. Anything I need to install?
Thanks for any help.
PS- I get less than 1 fps during gameplay and about 6 at the menu.
I don't know about you guys, but I though the GX2 would perform better with such a price tag :D
I'll try a GTX 280... ordered one last night... we'll see... still expecting an answer though... thanks
bpogdowz
703
AA/AF = off
texture quality = very high
Objects Quality = low
Shadows Quality = low
Physics Quality = medium
Shaders Quality = low
Volumetric Effects Quality = medium
Game Effects Quality = medium
Post Processing Quality = low
Particles Quality = medium
Water Quality = very high
Sound Quality = very high
NewLCD123
157
Wow Crysis must be the most intensive game out there. Can you set up 960x540 resolution? I wonder if your LCD TV can sync up to that, if so, the quality should be par to native 1920x1080 since the lower res is exactly 2:1 pixel perfect linear scaling.
snipingkid
125
Any idea what I need to do to fix my problem? Still getting 1 fps... haven't downloaded any hotfixes, patches or anything like that...
franto
Lowering the resolution doesn't always give more FPS in some situations.
This game is an open world and his low FPS is from the way it manage object distance.
Instead of using a fog like Oblivion it use ratio (that make things pop up at random)
The most FPS hungry setting of all is the vegetation ratio. In the configurations files not ingame setting.
The close setting ingame for this is object details.
My spec= 470gtx nvidia
phenom 2 4x 965
4GB ram
W7 64 bit
