[SOLVED] Low fps in csgo
Oct 15, 2019
5
I recently bought ryzen 5 2400g and corsair 8gb ram without graphic card... on looking others play using the same processor and ram on youtube they get good fps....but even when i changed csgo video settings to lowest possible...my fps cannot reach 100...its around 70 -80...what may be the reason for this?
List all of your specs including the PSU & memory speed.
AMD Ryzen greatly benefits from fast memory in dual channel so for example if your running a single 8gb stick @2400mhz then performance could be quite different then if it was a 2x4gb kit @3200mhz.
Also they could of overclocked both the CPU & iGPU (Vega 11) to achieve higher FPS.
You want to make sure you have the newest iGPU drivers installed.
https://www.amd.com/en/support
Last but not least they could be simply lying about the performance, it's messed up people would do it but not surprising nowadays.
