Hey everyone,
I just upgraded to a 2070 after my 780 died.
My issue is trying to play less intensive games such as CSGO or League of Legends. CS is using about 30% of both gpu and cpu, with very unstable frame rates of ~100 fps - 150, spiking to 200 at times, and dropping to 60. Leauge is using about 35% cpu and 15% gpu usage, while being very unstable with fps, usually under 100 and consistantly dropping or stuttering when there is action. My gpu temperature during both games is about 42 degrees. Cpu temperatures go up to about 50 degrees.
Running games such as The Witcher 3 and BF1 are fine, seeing 100+ fps, 95%+ gpu usage, and ~70% cpu usage. All settings are maxed out. My card gets up to 50 degrees.
I am not sure how to improve my performance as it seems that my card is not being pushed. I mainly want to achieve a higher fps and greater concistency. My 780 would always run at full power and get 250+ fps in CS, and about 150 in league. In The Witcher 3 I would get about 50fps with medium settings predominantly, and hairworks. Seeing how well The Witcher 3 and BF1 run expresses to me that my system should be able to run these less intensive games a lot better. I have updated all drivers, bios, and ensured my nvidia control power settings are set to max performance. Could my system be throttled somehow causing the less intense games to not run very well?
i7 4771 - air cooled
Gigabyte RTX 2070 3 fans
16gb 1600mhz Corsair Ram
1080p 144hz BenQ
Antec 850w HCG-850M
Windows 10
Latest drivers and bios
1080p 144hz BenQ
Antec 850w HCG-850M
Windows 10
