low fps in rust with gtx 1070ti and i7 6700k
Aug 14, 2018
17
hello, i play games on my computer and usually have no trouble getting 100+ fps on max settings for all games, but for rust i struggle to get above 60 on the lowest settings. I have an evga gtx 1070 ti 8gb and an intel core i7 6700k
Is your internet connection fast? I heard you need a fast connection for that game.
Yes my internet is fast.
My temps are stable and i play on 1080p, i recently wiped my computer to try and fix the issue but this did nothing.
SSD and HDD are your storage. Does your computer have a Hard Disk or Solid State Drive? Usually, SSD's in most computers are from 250 GB to 500 GB. How long does your PC to boot up?
Usually i leave it on sleep but when i turn it on after shutting it down its 2-4 minutes usually.
Sounds like an HDD then. This has me confused. How are your temps?
My temps are stable, the issue seems to be related to gpu usage but i have no clue how to fix this. when running my game my gpu stays at about 35%. Actually my cpu temp is at about 65 degrees Celsius while my gpu temp is at 45 degrees Celsius so my cpu temp is a bit high.
CPU temps are okay for your PC. Try DDU again, then reinstall. Not sure what else. Run memtest86 on those RAM sticks.
What do you mean try DDU again, sorry.
First off try reinstalling the game. Rust is a very graphics heavy game, and it is a very poorly optimized game. Double check your settings on Rust, make sure you're not missing anything. How recently did you buy your GPU and CPU, where did you buy it from, and for how much? A less likely problem is that you may have bought a fake graphics card, as 100 FPS is decently low for such high end specs, even when on max settings. What games do you play and can you give me a list of how much FPS you get for each?
Search up DDU. It is a software that completely removes all the Drivers for your graphics card from every on your PC. Then, re-install the drivers from the Nvidia page.
