Low FPS in WoW Cata
ahlamon
4
Hello everyone, I would like to get some opinion on why my FPS is as low as 4-10 on lowest possible video settings. Tryed everything, removing addons, playing in windowed mode, reseting all the settings (removing few folders) nothing really helped. Raids of 25 people are dramatically impossible to play, i have FPS of about 1-2 at the time.
My PC is as follows (checked in system req. lab and it passed recommended):
Motherboard
CPU Type Intel Pentium 4 531, 3000 MHz (15 x 200)
Motherboard Name Asus P5QL Pro (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Motherboard Chipset Intel Eaglelake P43
System Memory 4096 MB (DDR2-800 DDR2 SDRAM)
DIMM1: Kingston 2G-UDIMM 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Kingston 2G-UDIMM 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Type AMI (10/31/08)
Communication Port Communications Port (COM1)
Display
Video Adapter NVIDIA GeForce 8600 GT (256 MB)
3D Accelerator nVIDIA GeForce 8600 GT
Monitor LG L197W (Analog) [19" LCD] (1711197664)
Multimedia
Audio Adapter Realtek ALC1200 @ Intel 82801JB ICH10 - High Definition Audio Controller
Power supply
Modecom Feel III 350ATX 12cm FAN PFC bulk
P.S. It seems to be because of CPU, I have opened WoW in windowed mode again and ran task manager, cpu usage seems to be at 100% most of the time..
Thank you very much for your help in advance.
I am thinking if there is a point in the CPU (to something like e6600), or is it the problem that can be solved without that?
