Question Low FPS ---- is my PC running as expected ?
Hello
Just upgraded my pc to have a Nvidia 1660S and I'm having performance issues. Was recently on a rx 580 and it's a negligible upgrade. Getting 60-70 fps all low settings + max performance settings on a fresh install of windows with 90 render scaling on Warzone.
Can link a more in-depth benchmark as well if need be.
Thanks for the help
Reboot.
Wait a few mins.
Run userbenchmark with the browser closed.
Post a link.
geofelt
I sense that you expected that a 1660s would be a huge upgrade.
Yes, a very good graphics upgrade over a RX580
But, game performance also depend on the performance of the cpu.
Particularly the single thread performance.
I suspect that you were relatively well balanced on a cpu/gpu basis before.
Your upgrade addressed the graphics component and did nothing to the cpu component.
Run the cpu-z bench and look at the single thread performance rating.
You should get something like 566.
https://valid.x86.fr/bench/kn2lme/1
Many 9700k users will have overclocked to higher levels than yours.
If you have overclocked, give it a try.
If you are looking at a cpu upgrade, a <$200 i5-12400 will score about 700
A lga1700 B660 DDR4 motherboard will be about $150, and you can reuse your ram.
And, fwiw; userbenchmark is considered by some to be junk science.
