[SOLVED] Low fps issue please help
Jan 8, 2022
8
So I have build my pc a year ago and I have a lot of issues. My specs are atleast decent but I can't even get above 40 fps on GTA and I get max 150 fps and then it fps drops to 50 on Team Fortess 2
SPEC:
AMD Ryzen 5 2600 Six-Core processor 3400 Mhz
16GB RAM 3200 mhz
Geforce GTX 1660 SUPER
MSI b450m pro-vdh max
60hz Acer monitor
and if i remember corretly i have 650 watt's and a SSD (forgot about it and I don't know how to find the precise name n measurements)
My cpu is mostly on 15-25% and my memory 50% and gpu 10-45%
I've tried re-installing windows and I daily update my drivers. also tried lowering the graphics but that doesn't do much
Do I have to upgrade my specs or is there something else to it.
Thanks in advance
that GPU shouldn't have much problem maxing the 60Hz refresh rate with 60fps @ 1080p
but the CPU is a bit lacking.
your power supply can be a big factor so the make & model and time in use is necessary info.
