Not sure what is currently causing my FPS issues i'm running around 110 fps playing starcraft then as the game progresses I'm getting closer to 30fps current graphics settings are default high.
Originally I thought is was my Sapphire R9 290 overheating at 90C so I replaced it with a GeForce 1070 and still having fps issues
Here are my specs which I input into pcpartpicker.com and it says they are compatible:
MOBO: Gigabyte H97M0HD3
GPU: MSI GTX 1070 Armour OC Edition 8GB GDDR5
PSU: Seasonic 620W 80+Bronze
Processor: Intel i5 4460
Ram: Not 100% but its a 8gb stick
Temps Idle:
CPU: 32C
GPU: 46C
Under load nothing is above 60c
My ram usage is at 80% under load but I've been using the same build other than GPU for 3 years with no issues. I use a CAM app to monitor my PC speeds and temps and sometimes they are jumping radically.
All NVIDIA drivers are up to date and windows is as well.
Temps Idle:
CPU: 32C
GPU: 46C
