Low FPS on BF1
Jul 30, 2018
23
Hello, I have an FX-8350 paired with an rx-580, now, i know theres bottleneck but it shouldnt cause the problem that i have, which is having 30-40 fps very often, imagine that i can run doom and far cry 5 on ultra with 60+ fps. Ive seen others mention the ram, i have 16 gigs with a speed of 2000mhz. Please help
lmao, first of all, i saw you replied to some other guy who had the same problem, i was reading that before, now, for the settings, i normally run ultra 1080p 60hz, but even on low 1600x900 or 720p i still drop as low as 35-47
That's about right. Your cpu is majorly bottlenecking in bf1 as that game is highly cpu intensive. My friend who has my old fx 8320 system (oc'd to 4.6ghz atm) can keep a stable 60 fps often but still has a fair amount of drops or prolonged lower fps moments.
but the requirements say the cpu should run it perfectly
What it says is "Recommended requirements". What that means is up to the developers. Is 30fps good enough for them? Or does this mean I can run the game at 60? The devs decide what is playable for them.
If you look at review you'll see that the fx 8350 doesn't do too well in the game.
why doesnt it happen to other intensive games though? Gta V for example, all on ultra 1080p , battlefield 1 and sometimes battlefield 4 are the only games to do that
I would agree, could be the case, but im pretty sure other cpu intensive games run perfectly
