Question Low fps on cs2 - what should I upgrade?
Mar 30, 2024
4
i5-4670k 3.80 ghz
Gigabyte ga-h81m-h
Crucial 16 GB DDR3
GeForce gtx 1060 3 GB
SSD
What is the best upgrade to do that fits with my motherboard? Gpu or cpu? I have already tried all the settings, I really think I need to upgrade my hardware.
Thank you in advance
To put it blunt a new pc because upgrading 1 thing in your system leads to a bottleneck situation which doesn't really benefit you as much, long answer cs 2 is more performance taxing especially on higher settings than the former csgo. Your system seems quite old, how many frames are you pulling exactly? I'm making an assumption 150-250 on low settings @1080p ?
Okej I was afraid of that. Everything is set to low in cs2, updated all the hardware drivers, followed different guides. Cs 2 is almost playble but the fps drops in combat with all the smokes and <Mod Edit> stuff. Max 160 but drops to 50.
