low fps on good machine
Calvin Lao
im getting 80-120 fps on cs go with low setting and ive got a beast computer, can someone please help me make it run faster because my friend has the same pc as me and he runs at 350+ fps
pc specs
i7 4690k
8gb ram
240 ssd
1tb hd
4 gb asus strix gtx 970
gigabyte z97 d3h
cooler master 212x
corsair 750w bronze power supply
corsair 500r case
windows 8
samsung cheap optical drive
which drivers should i install because i just got my pc today
CSGO is graphic hungry game, especially when played on Multiplayer. Here's what you can do
* Update you Nvidia drivers to the latest ones
* Check in the Nvidia 3D settings that CSGO runs with the Nvidia GPU and not the Integrated one
* Disable V-Sync from the 3D settings, you don't need that.
Also , on what resolution are you playing?
Go to the Nvidia website and download the latest driver for the GTX 970.
I don`t use the variant driver (Asus in your case) because usually they have an older version driver on their website.
If you already installed "some" driver and you`re not sure if it`s the good one, after downloading the latest driver, use this before you install it.
You need to properly remove the old driver before you install the new one: http://www.overclock.net/t/1150443/how-to-remove-your-nvidia-gpu-drivers
I can help you to get all your Drivers,
Download Driver Booster from iOBit and Install it,Tap 'SCAN' and It will scan all the Missing,Outdated or Damaged (Corrupt) drivers and after it finish,Click on 'Update' so it Downloads Latest Stable version of a Missing,Outdated or Damaged Driver,Silently.
Also install latest version of DirectX,.NET Framework,Java and Windows Live (For Games) including all the Windows Updates
After that,Open your Case,and Clean the Parts (Fans) and especially the GPU and the PCI-e She sits on,Also the Power Connectors,Clean the VGA and HDMI Sockets and the Connector
That's it ! Thanks
