Hello everyone,
I recently bought a used pc for my brother who was playing warthunder on HP dv6 laptop with these specifications:
hp dv6 6177se
i7 2630qm 2~2.9ghz
8gb kingston ram (2x4)
ssd transcend 128gb
amd 6770m 2gb ddr5
he was playing on low setting and was getting an FPS around 80~120 on 1366x768 resolution. cpu and gpu is pretty old and its a laptop but still on low that is a great fps. Then I bought him a pc with these specifications:
i5-3570k @3.4 (stock)
8gb kingston ram (2x4 @1600)
gigabyte z77x-d3h
ssd corsair 128gb
gigabyte gtx 660ti
thermaltake smart se 530
win 8.1 64bit
i installed latest nvidia driver 350.12 and run furmark to test my 660ti score on 1080p and got average fps 32 and score of ~2000. Then I run warthunder on high setting (vsync off) to test the game and was shocked to see fps around 50 and dips to 20 is some places where you encounter multiple tanks.
I exit game and switched quality to very low and started. Got fps 80 and when I battle i get 20~30 fps which is really weird compared to the old laptop with 6770m gpu. Next tried to overclock the 3570k from 3.4 to 4.4 and got same results, only cpu got warmer but no increase in performance.
I tried another game like world of tanks and fps was great hitting 60 constant with vsync on on med setting.
Next I tried to take this gpu into another setup:
i5-4690k @3.5 (stock)
8gb kingston ram (1x8 @1866)
gigabyte z97-d3h
ssd transcend 128gb
corsair cx750
win 7 64bit
tried furmark and got exactly same score and fps on 1080p so it means card working well and also nothing wrong with first pc motherboard. Then lunched warthunder on med setting (vsync off) and got an fps of 140+ all the time which is confusing.
furmark performance are exactly the same using same 660ti but on two different setup, but warthunder ground force fps is way different. One is impossible to play on even lowest because of fps drop below 20 and on second pc always 140+ on med.
I hope you could help me determine the problem if it is my mobo, ram, cpu, driver, etc.
If you need any kind of tests or screenshots i'll make them fast.
Thank you very much
I updated the info down for more info. Waiting for your precious help
hp dv6 6177se
i7 2630qm 2~2.9ghz
ssd transcend 128gb
amd 6770m 2gb ddr5
gigabyte z77x-d3h
ssd corsair 128gb
gigabyte gtx 660ti
win 8.1 64bit
gigabyte z97-d3h
ssd transcend 128gb
corsair cx750
win 7 64bit
Thank you very much
