G gpuasker89 Honorable Dec 19, 2013 2 0 10,510 Dec 19, 2013 #1 I started a game at 60-65 fps then later it drops to 10-20 fps how could it be? I'm playing prototype 2.
Solution siddharthmukul007 Dec 20, 2013 update your bios as well as the drivers....see if that works. also see how much processor and gpu usage are you having
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 19, 2013 #2 what are your other system specs??? what temps are you hitting??? Upvote 0 Downvote
G gpuasker89 Honorable Dec 19, 2013 2 0 10,510 Dec 20, 2013 #3 My system specs-Intel core i5-4440,MSI b85-g43 gaming,aerocool strike x 600w,Kingston 8gb DDR3 1600,wd blue 1tb,sapphire r9 270x dual-x,Windows 7 home premium 64bit Temperature:48Celsius-61Celsius Upvote 0 Downvote
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 20, 2013 Solution #4 update your bios as well as the drivers....see if that works. also see how much processor and gpu usage are you having Upvote 0 Downvote Solution
