I am writing this post in order to see what is wrong with my pc or where the problem is. I've made a custom build PC but apparently when I play CS:GO I don't have more than 30-50 fps, as well as GTA V max 25-30 fps. I want to mention that all the settings are on very low values, only the screen resolution is set to 1920x1080 as the native resolution. Since I'm using windows 10 i cannot get in CS more then 50 fps, on windows 7 it was the same problem. I also would like to mention that I unparked the cores, done some settings on nvidia control panel which i found on the Internet aaaaanndd this setup was built in 01.01.2017....
I was thinking of buying a new graphics card, a 1060 with 6 gb. Any thoughts on that? Good investment or bad?
Pc Specs
CPU: Amd fx 6300 non OC and will not oc
MoBo: Msi 970 Gaming
GPU: Nvidia GTX 750 ti low profile
Ram: Hyper x 8gbr (1866)
Cooler: Deepcool maelstrom 120t
Hdd 1tb 7200 rpm 64 mb cache sata 3
Source 400 w segotep sg 400a
OS Windows 10
Monitor Benq 21,5 full hd
Speedtest.net
Download: 112,74 mb/s
Up: 23,04 mb/s
Ping: 21 ms
In game CS\
ping 50-60
lag spikes
1 nade 1 smoke and it freezes
Can someone pleas help me identify the main problem why my pc cannot run constantly 60 fps in cs?
I also built it on pcbuilder and as soon as i addet the gpu and cpu it said that they were incompatible which i think is highly unlikely....
Thanks in advance for your help and sorry for wasting your time with this post which you may have seen before or similar...
Pc Specs
OS Windows 10
Speedtest.net
Up: 23,04 mb/s
Ping: 21 ms
In game CS\
ping 50-60
lag spikes
