[SOLVED] Low FPS than other RTX2060
Apr 9, 2020
hello I have a 2060 rtx 6g for 1 year and sometimes in some games my FPS are less than normal even with the same configuration recommended. For example Doom Eternal, I would assume to be at 100 fps in ultra nigthmare and I am in 60 or 40 fps in ultra. other games do, and others don't. Do someone have some tips for helping me. my computer:
ryzen 7 1700x
rtx 2060 zotac 6g
16g RAM(one slut)
128g ssd
1t hdd
Your issue is the RAM. You're using 1 slot which mean that you're in Single Channel. This impact performance quite a bit on some titles. You need 2 sticks to get Dual Channel. So in your case 2x8GB RAM KIT.
Okay thanks !!! So do you know here i can get 2x 8g ddr4 Ram and can i get every model or a spesific model ?
