Low fps when streaming CS:GO with OBS
marcin00019
17
So I got low fps while streaming cs:go and I tried diffferent forums but I can't find help.
I try to stream at 720p60fps but even 540p gives me low fps.
I got a 144hz monitor so I need 144+ fps.
My specs are
FX-8350 at 4GHZ (I got a massive evo cooler on it)
12gb ram (although my windows 10 says 8gb is usable.)
Radeon HD7850 2gb oc'd
Windows 10
Please help I get like 80 fps and I tried multiple settings for the stream but I just cant figure it out.
i stream cs at 37 frames a second and its smooth as butter on twitch, viewers say it looks great
I'm playing at 144+ in game too.
I have a much stronger rig than you and im not willing to try streaming 60fps because I prefer to have smooth gameplay in game.
Open the Steam Overlay and change the Streaming options to "performance" rather than "quality". It's a nonsense, but quality caps your FPS to 30, which is just not enough to play CS:GO.
EDIT:
I didnt saw you were using OBS, Still, that happens when you stream using the steam overlay. Maybe the OBS has something similar. It's worth checking I'd say.
Man thats no help.
