Low FPS why?
ItsJack23
9
So the title says it all really, I am getting very low FPS on games where I shouldn't because of my PC stats..
My computer consists of:
GPU: GeForce GTX 780 Ti
CPU: Inter(R) Core(TM) i7-4790k CPU @ 4.00GHz
Memory: 16.00 GB RAM
Resolution: 1920x1080, 144hz
So judging by that there really shouldn't be many games I can't run well? I have recently factory reset my PC and have also just finished with the drivers installation. I thought this was resolve my issue of running the game on low FPS but it appears not.. What it may be is something in the BIOS i'm not aware of?
One thing I must also add is I have had issues with my CPU fan and it's running at 100% ( http://prntscr.com/6a6jlk ) and is nonadjustable, I have used AI Suite through the Dual Intelligent Processors 5 but I can't adjust the fan? (image) http://prntscr.com/6a5zpg
One game I have for an example is DayZ, I realise it isn't the best example as it's very non optimized but running on Medium quality I average about 20-30 FPS... I am currently re-downloading battlefield and will update when I get the benchmarks for that. Thanks,
*I am also running two monitors*
You may want to check and make sure that your drivers are update.
I also have dayz and have noticed low frame rates and lag that makes it unbearable. Check to make sure that your fan is plugged into the right port on your motherboard. These are the only suggestions I can give with my experience.
MOBO: Mod 1150 ASUS Z97 Maximus VII Hero ATX Motherboard
4 Sticks of ram (Corsair Vengeance 8GB (4x4GB) DDR3)
Monitors are plugged into a DVI and HDMI ports
Sorry mate but I'm not sure what the "Virtu MVP software" is? I still believe it has something to do within my BIOS..
