Hi, to start i have a major problem with my gpu, and I can't buy a new gpu/pc/pc part now. At the bottom I'll put pictures of what I'm gonna talk. I get low fps(30-60) at not even 1080p with my gtx 1050ti on many games, mostly on fortnite, which seem's akward to me because I have friends with "lower" graphics cards(like 750ti) that get higher frames and better quality. I can't go to a pc store to check my pc because I recently moved to Africa.
Here is my pc spec list (it's not pre build):
ok, than im gonna have to list
gigabyte gtx 1050ti oc windforce 4gb
intel dual core i5 650 3.20ghz
8gbs ram
windows 10 pro 64-bit
1tb HDD
320W power supply
now
my drivers are updated (416.16)
I have two monitors:
-1920x1080, 60hz
-1024x1280
my fortnite settings:
fullscreen
1600x900 16:9
unlimited(fps)
3d resolution 1600x900
view distance FAR
shadows OFF
anti aliasing OFF
textures MEDIUM
effects MEDIUM
post processing LOW
vsync OFF
motion blur OFF
fps ON
on nvidia control panel
adjust image settings with preview--> Use the advanced 3D image settings
ambient occlusion OFF
anisotropic filtering APPLICATION CONTROLLED
antialiasing-fxaa OFF
antialiasing-gamma correction ON
antialiasing-mode APPLICATION CONTROLLED
antialiasing-transparency OFF
cuda-gpus ALL
dsr-factors OFF
maximum pre rendered frames USE THE #D APPLICATION SETTING
multiframe sampled aa(mfaa) OFF
opengl rendering gpu AUTO SELECT
power management mode PREFER MAX PERFORMANCE
shader cache ON
texture filterin-aniso... ON
texture filtering-negative lod bias ALLOW
texture filtering-quality HIGH PERFORMANCE
texture filtering-trilinear optimization ON
threaded optimization AUTO
triple buffering OFF
vertical sync USE THE 3D APPLICATION SETTING
virtual reality pre rendered frames 1
my physx settings
processor:
GTX 1050ti
on aorus gaming app its on OC MODE
gpu boost clock:/1455
memory clock:/7928
I hope it's usefull because it took a LOOONG time to write all that/
8gbs ram
1tb HDD
320W power supply
now
-1920x1080, 60hz
-1024x1280
fullscreen
1600x900 16:9
unlimited(fps)
view distance FAR
shadows OFF
anti aliasing OFF
textures MEDIUM
effects MEDIUM
post processing LOW
vsync OFF
motion blur OFF
fps ON
cuda-gpus ALL
dsr-factors OFF
shader cache ON
my physx settings
processor:
GTX 1050ti
memory clock:/7928
