Question LOW FPS with GTX 1080
Jul 11, 2019
7
I recently bought a new build and thought seen as I was going be changing from a GTX 1050 Laptop to a GTX 1080 PC FPS in all games would improve BUT for some reason FPS is around 30-40
The new system I have is
CPU - i7 - 9700k
GPU - Gigabyte Geforce GTX 1080 Turbo OC
MBD - Aorus Pro z390
RAM - 32gb DDR4 3200mhz
All drivers up to date and I have tried uninstalling and reinstalling the gpu multiple times.
Anyone have any ideas?
Jul 13, 2019
5
Temps on both the GPU and CPU are fine around 50'c for Cpu and Gpu around 65'c
so maybe the problem technically from gpu itselt like it is not working probably you said all the games have fps problems so no way that a gpu like gtx 1080 can not run it so check the gpu it self try to change it or something
Jul 11, 2019
7
Everything else seems to be running fine on it thought, no physical damage, i have run health checks and it finds nothing
