Low fps with gtx 960m
Ankeee
Commendable
May 28, 2016
5
So i bought a pc few days ago, So i played minecraft and i had 1200 fps on there, then the day after in the morning i started my minecraft up and my fps only goes to 100-400, Can someone help me with this ? it worked fine before and now i have low fps 🙁
My Specs:
CPU: Intel i7 5700HQ
GPU'S: Nvidia gtx 960m (2GB GDDR5), intel hd 5600
RAM: 8GB DDR3L
On what settings did you have 1200fps? did you change any settings? 100-200 fps on the highest settings is what you get with a desktop 960.
Besides, if you have a 60hz monitor you don't see anything above 60fps.
I had everything on high settings in minecraft, and im on a laptop not desktop but it just annoys me because the fps decreased so much.
And i didnt change anything
1200 fps with a 960m on the highest settings is not possible. As I said the desktop 960 which is quite a bit better than the 960m, only gets around 100-200 fps while sometimes going up to 400 fps. But 1200 fps with a laptop gpu and cpu is not possible.
