Low fps: with r9 270x 4gig
Alexj1474
39
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
Processor: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz (4 CPUs), ~3.3GHz
Memory: 12288MB RAM
Available OS Memory: 12270MB RAM
Page File: 4130MB used, 20406MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Card name: AMD Radeon R9 200 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6810)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6810&SUBSYS_E271174B&REV_00
Display Memory: 1760 MB
Dedicated Memory: 4074 MB
Shared Memory: 1782 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HD2200
Monitor Id: GWY08A5
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1267 (English)
Driver Version: 13.350.1005.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 2/24/2014 00:08:16, 1328328 bytes
I have completely reformatted the computer and reinstalled windows 7 sp 1, reinstalled.
Ok so I bought the card for elder scrolls online. I tested the card too see what kind of fps I would get on older games, I used swtor and rift as my pigs so too speak. Both game stable fps rate was 45 on max settings and this card should be able too due better consisting my 6950 could play swtor at 120 fps or better.
Can anyone help?!?
Sorry, I don't remember the exact one for the CPU all I remember for now is that it's a i5 3.30 ghz. And I did the reformat because I need to get rid of a bunch of crap! Lol
And no vsync is not on.
There should be an update from Nvidia tomorrow or very soon which you can get on their website. Apparently a lot of people are having an issue with the newest update that they put out. Hopefully this will help your problem.
im using ati
Sorry I thought I saw Nvidia for some reason. Well you state that you're using a beta driver. Try to get the old driver the one right before the beta one.
that was the first thing i did, it had less performance then the beta did
