Low frames for my PC specs
STIHL
131
PC:
AMD Athlon x4 860k @4GHz
AMD R9 380x
16GB DDR3 RAM 1600MHz
I get very bad frames in games at 1080p which i don't understand because when comparing my PC to other benchmarks i get nowhere near the same frames as the benchmarks.
My GPU never goes above 70C on load and i do not use the stock cooler for my CPU so i doubt that is the problem. Even when i close all other programs, on BF1 i get average frames of 25 even on smaller game modes such as TDM on the high preset (Which is way below other benchmarks on higher presets). When i look at GPUz my GPU load flicks between 100% and 0% rapidly.
I have always had frames like this and i have only just checked other benchmarks as i have assumed my CPU was the component bottle necking the system (which i know it is) but i just wanted to see if DirectX12 makes any improvement, this is where i saw the difference in frames between my PC and others with similar components.
I have the latest drivers on my PC and i used GPUz and saw the GPU usage going from 0%-100% constantly whilst on load. I did recently change my old CPU AMD A8-7650K to an AMD Athlon x4 860k that my brother brought but never used so i expected a slight increase to frames but there was no difference.
