Low FurMark Score
subzerolord
13
I am trying to determine if my GPU is working or not and I tried using the FurMark benchmark test at preset: 1080 (FHD).
After running the test:
Score:148 points (2 FPS, 60000 ms)
Max GPU Temp: 45°C
Resolution: Resolution: 1920x1080 (FS) - AA:0 samples
FPS: FPS: min:3, max:4, avg:2
GPU core: 850 MHz, memory: 1200 MHz
Does this results show my GPU is failing?
Thanks!
Windows 7 SP1 64-bit
Intel Core i3 CPU 530 @2.93 GHz
AMD Raedon HD7770 Series
Motherboard: GIGABYTE H55M-S2
PSU: PowerWide ATX-430W
Ram:4GB Kingtson Ram KVR13N9S8/4 x2
Well thats true, I don't really face any issue while gaming. Thanks!
