Low gpu usage BF3, minecraft other games! HELP! <3
On some websites I read an amd phenom 9600 maximum functioning temp is 70 degrees and while I play bf3 my cpu temp goes up to 66 67 max my gpu temps are so low! My gpu temp is like 35 degrees max 40.
One time I tried overclocking cpu from 2.3 - 2.412 something and I ran to check if the cpu was stable and I didn't get time so I just started to play and for some reaoson my computer turned off because of over heating.
Well there's good news and bad news here. The good news is that your CPU isn't throttling due to the heat, the bad news is that you are still lagging, so something else is causing this.
Run a scan with this to see if some virus is using up your resources: http://www.malwarebytes.org/
Nothing 🙁 I already have malware bytes
