Low GPU Usage help
nigisama123
57
Hello! i have the gtx 970 but i dont seem to get the fps i'm suppose to get.. i play league of legends and i very inconsistent between 200-300.. i asked other gtx 970 owners and they reach 500.. and im only using 1600x900.. i have high settings on league and i only get 30%+ GPU usage.. how do i change it>>
Have you put the battery/power to high performance and changed the power setting in the GPU control panel and look for the tab with (Prefer high performance)
i know 300 fps is not necessary for league but, what bothers me is that my gpu is not performing on what its expected to be performing.
Have you tired wiping the driver with driver sweeper? Then reinstalling the latest driver.
What over games have you tried the card out on? As for example when I play some games even with an uncapped frame rate the GPU won't go 100% due to the game not taking full advantage of the GPU and CPU as the game wasn't developer for such high end hardware. I have i5 4460 and MSI GTX 970 4GB (EVGA G2 550w Gold).
Try a bunch of games on max and report back. Use the program called afterburner to monitor your hardware while gaming, you can find quick starter videos of the monitoring program on youtube.
