Question Low GPU usage problem ?
GPU: RTX 4060 Ti 8GB
Gpu only gets about 30-60% usage no matter the game I have no idea I’ve tried driver uninstall with udd and installed back. Everything in bios and in the control panel. I got the gpu for a great deal hopefully someone can help. Thanks.
Specs:
MBD: ROG B450 Gaming II
CPU: Ryzen 5600G
RAM: 16GB 3200MHz
Am I missing it, did he mention his CPU usage during these games?
Even at PCI 3.0 the graphics card is waiting for the the rest of the computer to catch up. I.E. the CPU is rendering slower than the graphics card and thus the graphics card is waiting on the CPU or some other bottle neck in the system.
Specs:
CPU: Ryzen 5600G
RAM: 16GB 3200MHz
Hello:
performance rating with price reference. and Compatible
Nvidia GTX 1050-Ti 3.9/5
Nvidia GTX 1060-6GB 4.8/5
Probably the GPU you installed is not compatible with ROG B450 Gaming II
For the best performance. and comparable with the ROG B450 Gaming II reference
recommended Memory clock speed ‎4400 MHz: Performance rating 5/5
RAM memory maximum size ‎24 GB. therefore 3x (8GB): Performance rating 5/5
Ask the store if they can exchange it for your GPU and Memories.
and before the Purchase You could check the specifications and compatibility of the Hardware.. with these characteristics.
what the cpu usage? ram?
brand and model of the psu?
what game? what resolution?
If I play hell let loose it will only reach around 38-60 usage on all settings in 1080p the psu is a evga 750w and the ram usage is about 71% I was playing on a better cpu and motherboard soon I don’t know if it can affect it either the card can only run 3.0 and not 4.0 on the motherboard. Thank you.
Also even csgo only gets 30% it only gets like 115 fps every setting.
Latest posts
