Low power media server
G
Guest
Guest
Hi, I need to build a PC that uses the least amount of power but will be able to be used to stream HD moves to either a xbox 360 or a media streamer which i will buy later (probably a popcorn hour) i am wondering if the current processor and motherboard i have will be sutable for this. i have currently: AMD Sempron 3000+ and a AMD Sempron 2600+ processor. a Winfast motherboard 760gxk8mc Motherboard and a Asus k8v-mx Motherboard. i also need a power supply and want to know the minimum amount of ram required for hd streaming and also if there is a way to remotely tell the computer to download rapidshare links.
Thanks in advance :)
Alvin Smith
3,477
61
AnandTech CPU Bench
AMD Sempron 1300LE vs. ATOM D510
http://www.anandtech.com/bench/Product/41?vs=110
Well, I am NOT the world's foremost authority on media streaming server builds BUT ...
I do know that the ATOM D510 is (barely) suitable, for this purpose and, this (latest) ATOM is outpaced (marginally) by a Sempron 1300LE (which I can only guess, is slower than either of the Semprons that you listed.
SO ... As far as proc power goes, you should be OK ... I would investigate (on MS website) if these CPUs (your semprons) provide 64Bit support for Win4-64 (If that is your OS of choice) ... Just be sure the OS you choose does fully support your CPUs.
As far as the RAM goes ... I can only say that the ATOM based SOHO servers, on newegg, are usually configured with 2 GB ... I would recommend 4GB, but your limited application prolly does not really require more than 2GB ...
... DDR2 and 2-ch RAM of any speed should be snappy enough.
... Essentially, this is a network file server ... no ? ... The speed of the HDDs is what is prolly most critical ...
... I would recommend a Gigabit 1000/Base-T CAT5 connection of 50 feet (or shorter) and a Seagate 7200.12 1TB drive (fast enough and one of the more quiet performance drives ... about ~$75)
= Al =
PS: This is all tentative but I don't see how you could go wrong ... as long as you check all sw/hw requirements.
G
Guest
Guest
Thanks Alvin ill start looking at AMD Sempron 1300LE now. Essentially yes it is a file server but i want the least amount of power used when idol. I was thinking of underclocking the Semprons but if the Sempron 1300LE is better and uses less power then i will buy one of them.
Thanks again
Alvin Smith
3,477
61
Well ... I'm pretty sure the ATOM D510 uses the least power of all AND it is essentially on par w/the 1300LE ... but, if you have other parts, for an AMD build, at hand ... well ... go that way.
= Al =
Similar threads
