Question Low power system with gpu 400-500 USD budget.
Spankymcbob1
273
Trying to figure out what would be better for a low power system with a video card.
The budget is like $400-500.
I was thinking about using the 2200g or the current gen i3 for the cpu.
Then an ITX board
Some Small ITX case
Only gonna us a 240GB SSD, I don't think that I need anything higher for the few games that will be installed on this system.
For the ram I would prefer 8-16GB depending on what the budget allows.
Then for the gpu I'm not really sure. I know I could just get a gtx 1050 ti, but I heard the rx 480 is super cheap and doesn't take to much power.
If people could put together a few builds around my idea that would be great.
Thanks,
PCPartPicker Part List
CPU: AMD - Ryzen 3 1200 3.1 GHz Quad-Core Processor ($65.85 @ OutletPC)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard ($65.99 @ Newegg)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory ($45.88 @ OutletPC)
Storage: Kingston - A400 240 GB 2.5" Solid State Drive ($29.99 @ Amazon)
Video Card: Sapphire - Radeon RX 580 8 GB PULSE Video Card ($179.99 @ Newegg)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case ($45.98 @ Newegg)
Power Supply: SeaSonic - S12III 450 W 80+ Bronze Certified ATX Power Supply ($39.98 @ Newegg)
Total: $473.66
Generated by PCPartPicker 2019-05-20 17:36 EDT-0400
*You could save some money by buying a used RX 580, then you could get a better CPU like the Ryzen 5 1600 for $119.
