Question Low power video cards
jtelep
5
Has anyone ever heard of motherboards that will only recognize graphics cards that do not require external power? I’ve never heard of this but I am currently using a BioStar A785GE AMD mainboard that has an onboard Radeon 4200 HD with an AMD Athlon X2 3800+ and no matter what card I try, if it requires any external power, the board will not recognize it but as soon as I switch to a low power card it works fine.
Thanks!
Thanks!
If a GPU has external power connector you must use it. Typical PCIe port can provide only up to 75W that's why higher powered GPUs need added power.
jtelep
5
Right, what I'm saying is that when I plug in the external power to the card via the PSU it is still not recognized however if I use a card that does not require external power it works fine.
